15 Users Online (13 Members):
Forums >> Revit Systems >> Tips & Tricks >> Space Issue
9 Posts No Rating |
I'm having a problem with spaces. I'd like to define the space as not the finish part of the wall but center of the wall. I know you can do this for rooms and area, but I want to know if you can do it for spaces.
I think that your question needs to be more specific please? Give us an example what are you talking/need...
Are you talking mechanical ?
9 Posts No Rating |
Ok so I have a room that is 10'x10' from inner wall to inner wall. This gives me an area of 100 sqft. However, I want to be able to change the area to read from centerline to centerline. This is essential for electrical calculations.
Change the "Area Boundary Line" to create a new perimeter for that space....
I believe MEP's spaces are different than arch rooms and areas.
9 Posts No Rating |
They are. That was my question if I could change how the space reads the sqft like I can do for archiectural area's and rooms.
4 Posts No Rating |
I think you are stuck due to the room bounding option. That has to be check in your arch model to make MEP spaces work. I have tested it out a little in my project and I can't find a way to get the space area to go beyond the bounding elements of the room. Good Luck Please post your solution if you find one.
Inner space is not surrounded by outer space with higher height. |
Thu, Sep 6, 2012 at 8:34:57 AM
Importing .dwg Details - Model Space vs. Paper Space |
Wed, Aug 9, 2006 at 5:37:45 PM
Basic Scaling issue |
Fri, Feb 26, 2016 at 12:35:16 PM
Cant place space tags.. even though some space tags exist.. |
Tue, Feb 9, 2016 at 9:46:47 AM
Importing Paper Space/Model Space from CAD File |
Mon, Nov 17, 2014 at 9:46:02 AM
