Forums >> Revit Building >> Technical Support >> Project Units
Fri, Sep 30, 2005 at 9:58:29 AM | Project Units
DHerbert
DHerbert Avatar
I know that you can change the precision of units under SETTINGS and would like to know if it is possible to set the precision to say 1/2" for larger plans and 1/8" for project details.
Fri, Sep 30, 2005 at 10:34:26 AM | RE: Project Units
Rythmick
5 Stars: 2 Votes
Create different dimension styles with different unit accuracy settings.
Fri, Sep 30, 2005 at 10:37:49 AM | RE: Project Units
DHerbert
DHerbert Avatar
Thank you. This is our first project in Revit and I'm not sure how to apply a different dimension style. In Word you select the text you want to be affected by the style. Once you create the appropriate style how do you apply/change it within a project?
Fri, Sep 30, 2005 at 11:23:01 AM | RE: Project Units
Rythmick
5 Stars: 2 Votes
Go to your current dimension properties and "Edit" - "Duplicate" - change the "Units Format" parameter.
Working With Individual Units as Part of Multi-Unit Project
Fri, Sep 17, 2010 at 7:00:01 AM
Areaplan not in project units
Thu, Sep 1, 2011 at 1:15:32 AM
Conversion from English Units to Metric Units
Tue, Feb 17, 2009 at 4:32:52 AM
exporting to navisworks mwc file ...what units ???
Mon, Jan 24, 2011 at 6:15:53 AM
Project Units Question
Tue, Oct 9, 2012 at 4:35:25 PM
Page generation time: 2.1066
