Forums >> Revit Building >> Technical Support >> Adding Views to Sheets in 2010
Mon, May 24, 2010 at 3:00:50 PM | Adding Views to Sheets in 2010
RemNYC
Hi all,
I just updated to Revit 2010 and I'm trying to duplicate (with detailing) a plan view and then add it to a new sheet.  I used to just drag the new view onto the sheet.  This still works except now the view is no longer showing up under the "views" branch in the project browser.  When I look at the properties of the sheet it is still "located" in the view category that I had placed it in, but I can no longer see it there.  Is there something I've missed, or is this a new feature of 2010?
 Thanks for your help!
Mon, May 24, 2010 at 3:23:04 PM | Adding Views to Sheets in 2010
The copied view will be in the same browser area and will be named ..."Copy of XXXXX"
Mon, May 24, 2010 at 4:13:13 PM | Adding Views to Sheets in 2010
RemNYC
sorry, maybe I wasn't clear... when I create the copied view it does show up as "copy of xxx" and then I re-name it and place it in the correct view folder of my choosing.  then i drag it to the sheet I want it on, and it appears there, but disappears from the "views" branch.  does this make sense? thanks!
Mon, May 24, 2010 at 4:47:34 PM | Adding Views to Sheets in 2010
You place it in the correct folder?  You mean you assign it to some sort of "sort" parameter.
"...but disappears from the "views" branch.  does this make sense?" .... absolutly not.  Is your browser sorted to only show views not on sheets? Change your browser sort to show all and see if it is there.
Thu, May 27, 2010 at 3:18:58 PM | Adding Views to Sheets in 2010
RemNYC
That worked! Thanks very much.
Sheets and Views
Wed, Mar 17, 2021 at 3:23:24 PM
views and sheets for revisions [ 1 2 ]
Fri, Mar 11, 2011 at 9:21:39 AM
20
Create Work views
Thu, Feb 18, 2010 at 3:38:08 PM
printing sheet sets - only the sheets
Wed, Jul 18, 2012 at 3:10:10 PM
Identifying placed / unplaced views
Mon, Nov 29, 2010 at 8:00:33 PM
Page generation time: 0.4029
