Forums >> Revit Building >> Technical Support >> How to pin irregular (custom spaced) horizontal curtain wall grid
Mon, May 24, 2010 at 11:33:03 AM | How to pin irregular (custom spaced) horizontal curtain wall grid
tonini
Is there a way to move horizontal curtain wall grid at irregular (custom) spacing and then pin the grid so that any new curtain wall drawn afterwards to retain the spacing of the horizontal mullions.  The goal is to have the new walls created later to keep the custom horizontal spacing of the curtain grid.  (for Revit 2009).  Thanks!
Mon, May 24, 2010 at 11:48:42 AM | How to pin irregular (custom spaced) horizontal curtain wall grid
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
tonini look at the botton of this page there are some tread about your question i guess.
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Mon, May 24, 2010 at 12:03:43 PM | How to pin irregular (custom spaced) horizontal curtain wall grid
tonini
...from what I read it does not seem possible to define custom horizontal curtain wall grid that is re-created with the same spacing when a new segment of the same wall type is drawn...may be in the next version...Thanks for the help!
Mon, May 24, 2010 at 12:16:36 PM | How to pin irregular (custom spaced) horizontal curtain wall grid
Did you just try and copy your irregular spaced CW to another location?
Wed, May 26, 2010 at 1:19:17 PM | How to pin irregular (custom spaced) horizontal curtain wall grid
tonini
coping the wall (with irregular horizontal mullion spacing) and then adjusting the lenght by stretching or aligning works!...simple... I should've thought of it...thanks for the tip!
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
curtain wall super custom grid
Fri, Sep 11, 2015 at 9:41:09 AM
Curtain Wall Grid Issues
Tue, Dec 23, 2008 at 8:47:00 AM
Curtain wall grid
Sat, May 28, 2016 at 9:58:45 AM
Revit 2013 Curtain Wall Variable Grid Spacing
Thu, Jul 18, 2013 at 2:10:54 AM
Page generation time: 0.7773
