Forums >> Revit Building >> Technical Support >> Rotation
Fri, Sep 30, 2005 at 8:42:22 AM | Rotation
DHerbert
DHerbert Avatar
Rotation: Can you change the center of rotation for a component? Example: Rotating individual lockers to align with a radiused wall. The COR is out in front of the locker and I have to move it manually to the bottom left corner in order to rotate it so that the back of the locker aligns with the wall. I have lockers on both sides of the hallway that each need to be aligned with the inset wall so when I move across the hallway to rotate my lockers I will need to change the COR for those lockers too. Any suggestions?
Fri, Sep 30, 2005 at 10:25:04 AM | RE: Rotation
Rythmick
5 Stars: 2 Votes
I don't think so -I've seen this one on wish lists.
Fri, Sep 30, 2005 at 11:17:04 AM | RE: Rotation
Rythmick
5 Stars: 2 Votes
A possible solution would be to make the locker a wall based family and reinsert them. If Wall based they would align to the wall.
Wed, Feb 27, 2008 at 2:28:49 PM | Rotation
hank
3.5 Stars: 3 Votes
 It seems to me that the COR is placed at the CENTER OF THE family's extents.  Thus, if you want the COR at one edge, you can draw an invisable line out in space about a full width away from the model to accomplish this.  Takes some trial and error, but I was able to get thius to work.
Edited on: Wed, Feb 27, 2008 at 2:31:10 PM
View Rotation on Sheet
Thu, Jan 18, 2007 at 10:12:38 AM
View Rotation on a Sheet
Tue, Feb 14, 2012 at 1:32:37 AM
Is it possible to set/command 'Fixed Rotation' to elevation line
Tue, Feb 27, 2018 at 4:13:50 PM
Family type control for rotation?
Fri, Mar 14, 2008 at 6:15:14 AM
Tue, Oct 27, 2009 at 12:35:35 AM
Page generation time: 0.0301
