Forums >> Revit Building >> Technical Support >> Revit MEP 2011: changing a data device to telecom device
Thu, May 20, 2010 at 4:05:42 PM | Revit MEP 2011: changing a data device to telecom device
kc76
Hello I'm new to Revit, but is there away to change multiple data devices to telecom devices? When I edit the data type and try to load the telecom device family it wont let me because its a different category. Any help is greatly appreciated thanks!
Thu, May 20, 2010 at 6:09:54 PM | Revit MEP 2011: changing a data device to telecom device
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
If it doesnt load is because you re working with a different category as it says. try to upload in a different way. not from the objects properties but from the load family on the RIBBON. I hope it helps .
Edited on: Thu, May 20, 2010 at 6:12:40 PM
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Thu, May 20, 2010 at 6:42:52 PM | Revit MEP 2011: changing a data device to telecom device
kc76
i can get the family loaded that i need into the drawing, I guess my question is, is there a quick way to replace the devices i already have in the drawing with the correct one if they are 2 different family cateogories (data and telephone) thanks
Laser Measuring Device with Bluetooth data transfer
Fri, Nov 23, 2007 at 9:29:52 AM
Change From Electrical Fixture to Communication device
Tue, Aug 15, 2006 at 11:11:52 AM
Ductwork connected to air device displays flow in one model but not another
Fri, Nov 15, 2013 at 7:33:41 AM
Rotating text/label within annotation symbol
Tue, Oct 6, 2015 at 11:07:27 AM
Newbie - Electrical user
Fri, Oct 26, 2007 at 2:04:45 PM
Page generation time: 1.4063
