Forums >> Revit Building >> Technical Support >> Revit crash when dimensioning
Wed, May 19, 2010 at 10:58:48 AM | Revit crash when dimensioning
ELPfeff
Hi, I need help if you can give it!
My revit program keeps crashing. I am using 2011 on a VAIO. I just updated the graphics card driver, and it continues to crash, and so I am beginning to think it is the file. How can I fix this? I tried auditting the file with no luck. Please help!
Wed, May 19, 2010 at 12:52:10 PM | Revit crash when dimensioning
4 Stars: 205 Votes
You didn't told what is the SPEC of your computer.... Ram, Processor...file size....
Thu, May 20, 2010 at 11:08:51 AM | Revit crash when dimensioning
ELPfeff
The computer specs are not a problem. We just bought this computer, it has an intel core i7 cpu @ 1.60ghz and 6 gb of RAM. 64bit op system and windows 7. I sent the file to Autodesk because we have a subscription, and they claimed to have repaired it, which they did not. Basically, in one view, in a callout of a wall section, if I try to dimension from either the exterior wall, or from the edge of the cat walk, the file because unstable and a warning pops up to tell me to save to a recovery file, but does not shut down revit. Any suggestions?
Thu, Jun 24, 2010 at 12:21:18 AM | Revit crash when dimensioning
Chrisg12345
your problem i think is that since revit 2011 is new and you have Nvidia Geforce cards nvidia has not updated the display drivers to work with revit 2011
your problem will be fixed by installing any Nvidia Quadro FX cards which are certified by autodesk and nvidia to have full stable functionality.
 if you require a place i would recommend to buy such cards or workstations in genral i can point you in the right direction.
Wed, Jun 30, 2010 at 5:26:15 PM | Revit crash when dimensioning
Jackicraig
This might be a stupid answer, but I had something similar happen where my model kept fatally erroring whenever I'd do certain operations on a certain wall. I deleted and redrew the wall, and the errors and warnings went away. It sounds similar to what happened to you, so I'd give it a shot. Especially if the other walls are working fine.
Wed, Jun 30, 2010 at 7:02:04 PM | Revit crash when dimensioning
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Sometimes a particular view will get... corrupted.  In my experience, I've had 3D camera views that have a beruda triangle...  where revit gets confused and simply cannot render the geometry, and slows to a crawl, or crashes.  Delete the view and remake, or try duplicating it.
I'd put my money on updating the graphics card drivers, though.  I just got a new card myself and it included a driver version dated 2007.
Thu, Jul 1, 2010 at 4:01:08 AM | Revit crash when dimensioning
4 Stars: 205 Votes
Jackicraig, what version of Revit do you have? there are several Hotfix to 2010 about that "wall" problems like you can see here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944#section1
About 2011 you have the "Update 1" to fix some issues like you can see here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
Tue, Jul 13, 2010 at 9:20:13 PM | Revit crash when dimensioning
ant
ant Avatar
We are having exactly same problem. Dimensioning anything in any section view crashes Revit. It is happening on multiple machines (including Macbooks) so it is doubtful it is a hardware or driver issue.
I have installed 2011 update and it has not helped.
All users are using Revit 2011 64bit on Windows 7 & Vista.
Tue, Jul 13, 2010 at 9:57:57 PM | Revit crash when dimensioning
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
lucky me, im still on a 32 bits YAY
Wed, Jul 14, 2010 at 1:48:42 AM | Revit crash when dimensioning
gebber
gebber Avatar
5 Stars: 4 Votes
Does revit also crash when dimensioning verticaly?
I discoverd when the section is not 100% perpendicular to the view you'll get an error and the question to save a backupfile, when clicking yes it doesn't shut revit down and you are able to continu in the same session.
Thu, Jul 15, 2010 at 2:07:57 AM | Revit crash when dimensioning
#11
ant
ant Avatar
We think we worked out the cause:
Walls were not quite perpendiclar to grids, 90.00001153449° instead of 90° (see attached screen shot).
When sections are created they make themselves parallel to the nearest thing (usually a wall).Therefore sections were not exactly perpendicular to grids.
Unfortunately there is no way to align sections.So after aligning the walls to grids, we had to re-create all the sections.
Revit is very unforgiving, it will not tolerate sloppiness.
Lesson learnt: keep Rhino users away from Revit!
Thu, Jul 15, 2010 at 7:38:36 AM | Revit crash when dimensioning
#12
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
DO YOU HAVE THE "GRAPHICS ACCELERATOR" ENABLE IF SO UNCHECK IT
Crash!!!!
Thu, May 5, 2011 at 4:09:10 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Revit Link causes crash
Wed, Dec 29, 2010 at 10:33:38 AM
Crash for single user on workshare projects
Thu, Jun 26, 2014 at 2:56:50 PM
Parametric Cabinets causing crash in RAC 2010
Tue, Aug 11, 2009 at 1:21:18 PM
Page generation time: 1.2872
