Forums >> General Discussion >> Revit Project Management >> Turn Revit line to look like hand sketch lines
Mon, May 17, 2010 at 7:03:23 PM | Turn Revit line to look like hand sketch lines
jgmas
is there a way in Revit to turn a model or 2D line drawing to look like a hand sketch drawing ?
I know it can be done in autodad but not sure if Revit allows to do that as well.
thanks
Mon, May 17, 2010 at 7:22:34 PM | Turn Revit line to look like hand sketch lines
TomDorner
4.5 Stars: 25 Votes
Short answer: no
Long answer:  You can export Revit views a 2D CAD files and use whatever you would use in the CAD world to sqiggle the lines.
Tom
Mon, May 17, 2010 at 7:41:02 PM | Turn Revit line to look like hand sketch lines
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
if you are on subscription at the download center you may download Autodesk Impression.... I'm pretty sure it's still free. You can then export DWF formats to Impression and quickly create sketchy hand rendered looks. Super easy program to learn, should take about 20 minutes to figure it out.
Tue, May 18, 2010 at 11:02:08 AM | Turn Revit line to look like hand sketch lines
jgmas
ok thanks,
i able able to do it in CAD 2010 but only in 3D view, how/where can it be done in 2D?
I know this is a revit forum and not CAD but any help is appreciated
Tue, May 18, 2010 at 3:18:06 PM | Turn Revit line to look like hand sketch lines
TomDorner
4.5 Stars: 25 Votes
As the previous post mentioned Autodesk Impression does a decent job with either dxf or dwg files and is free for subscription customers.
There are other dedicated programs like Squiggle  [do a web search].  You could export as dwg and use Sketchup.
The list is probably endless.
Tom
Sketch Rendering
Thu, Sep 30, 2010 at 10:13:46 AM
Split Face Sketch on Floor Completes then Displays Error: Line is Too Short
Wed, May 22, 2013 at 3:12:37 PM
Filled Region Sketch Mode
Tue, Nov 17, 2015 at 1:28:34 PM
Sketch Line Style
Wed, Jun 25, 2008 at 2:19:10 PM
curtain wall sketch snapping problem
Wed, Aug 12, 2009 at 8:54:07 AM
Page generation time: 1.6159
