Forums >> Revit Building >> Technical Support >> Sweep on Stacked Wall Error
Mon, May 17, 2010 at 4:28:56 PM | Sweep on Stacked Wall Error
Thehiddenthought
Thehiddenthought Avatar
Whenever I try to "add or remove walls" for my sweep, the following error comes up: "There is a circular chain of references among the highlighted elements" on a stacked wall.  I'm wondering what's wrong?  BTW I'm using Revit 2009 for this project.
Thehiddenthought
Wed, May 30, 2018 at 2:24:43 PM | Sweep on Stacked Wall Error
mike102
3 Stars: 2 Votes
The only thing that works some of the time to avoid this issue is to select the stacked wall first then the other interior walls. This will sometimes avoid the error.
Stacked Wall Sweep Returns (RAC 2008)
Mon, Nov 5, 2007 at 8:49:08 AM
stacked wall sweep cleanup
Fri, Feb 12, 2010 at 9:11:19 AM
Stacked Wall Sweep Joined but do not intersect 2013
Thu, Mar 7, 2013 at 4:45:15 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
Stacked Wall with Wall Sweep
Mon, Oct 5, 2009 at 4:34:41 PM
Page generation time: 2.8680
