Forums >> Revit Systems >> Technical Support >> duct connector
Mon, May 17, 2010 at 2:15:28 PM | duct connector
vinnygolfer
4.5 Stars: 4 Votes
hi everyone, here is a real world situation that i need help with. i'm using mep 2010. i have an existing building with a main supply duct that runs down 4 floors from the penthouse to the basement. at each floor it has a take-off from both sides of the duct and then the main continues, but at a reduced size. there is not a reducer on the duct it just splits off like the pants connector, but with 3 legs. here is an example of it. anyone have any idea of how to make a connection that will do this?
Try to learn at least one new thing every day
Tue, May 18, 2010 at 6:08:02 PM | duct connector
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
I created the attached duct fitting awhile ago for a demonstration so needless to stay it is kind of dirty and might need some tweeking on your end but you are able to change the branches between mitre and radius. hth.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, May 19, 2010 at 7:06:05 AM | duct connector
vinnygolfer
4.5 Stars: 4 Votes
thanks that does just what i needed.
Duct Connector Not Visible??
Thu, Feb 17, 2011 at 11:41:00 AM
Family Editor - Duct Connector
Mon, Jun 16, 2014 at 1:52:01 PM
Duct won't tap to oval duct.
Tue, Aug 22, 2017 at 12:38:49 AM
Side duct grilles?
Fri, Sep 28, 2012 at 10:52:50 AM
turn off connector labels in Revit 2012
Wed, Oct 12, 2011 at 1:06:29 PM
Page generation time: 2.1765
