Forums >> Revit Building >> Technical Support >> crop regions and text
Wed, Sep 28, 2005 at 10:25:26 PM | crop regions and text
cirostratus
Hello, I have text outside of a crop region that I DO NOT want to show but for some reason it IS. The model parts dissapear properly but the annotation doesn't. Is there a setting that will make everything outside of the crop region dissapear? Thanks for your help..
Wed, Sep 28, 2005 at 11:39:05 PM | RE: crop regions and text
cirostratus
Here is an example of my problem. I have the crop region visible in the lower left hand corner and you can clearly see the wall are cropped properly, but there is a lotta text outside of the region at the upper right that I need to turn off. Does anyone know what I'm doing wrong?
Thu, Sep 29, 2005 at 4:34:18 PM | RE: crop regions and text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The text and dimensions are view specific and as such doesn't comply with the crop region. You'll have to delete the text outside of the crop region. In most case when detailing a view you'll need to place text outside the crop region so as to not conceal the model you are trying to show...
Fri, Sep 30, 2005 at 4:06:43 AM | RE: crop regions and text
cirostratus
Thanks for your help!! Got it!
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
Crop Regions can't crop imported images
Mon, May 5, 2008 at 2:25:13 AM
Changing Lineweight of Crop Regions
Mon, Jun 19, 2017 at 8:39:07 AM
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Irregular Crop regions (Revit 2008)
Mon, Jan 28, 2008 at 12:00:04 PM
Page generation time: 1.0138
