Forums >> Revit Building >> Technical Support >> Electrical symbol tags
Wed, Sep 28, 2005 at 12:39:28 PM | Electrical symbol tags
johnfire
Does anybody know if there is a way to have a letter with an electrical symbol, say a downlight, that can be put in a schedule? Or am I going about this the wrong way? I am trying to put in lights in an electrical plan and then schedule them. Thanks John Fleming
Wed, Sep 28, 2005 at 5:09:33 PM | RE: Electrical symbol tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can create a graphic legend for the lights. Then add a text schedule next to it on the sheet. This will ensure everything is parametric.
Thu, May 3, 2007 at 11:58:06 AM | Electrical symbol tags
varevit
I KNOW THIS IS A BIT OUT OF DATE, BUT:
FILL IN THE 'TYPE MARK' FOR THE FIXTURE, AND THEN ADD 'TYPE MARK' TO YOUR VISIBLE COLUMS IN THE SCHEDULE.
YOU WILL ALSO BE ABLE TO THEN USE A LIGHT FIXTURE TAG TO LABEL IT ON YOUR SHEET.
Electrical symbol + 3d drawing
Mon, Sep 13, 2010 at 3:31:43 PM
Symbol Electrical Schedule - How to?
Tue, Apr 30, 2019 at 5:10:52 AM
Parametric Electrical Symbol
Wed, Jun 16, 2010 at 6:21:47 PM
Mechanical Equipment with Electrical connections showing 0V
Mon, Oct 11, 2010 at 8:13:43 PM
electrical symbol families
Fri, Jun 5, 2020 at 3:57:35 AM
Page generation time: 1.6775
