Forums >> Revit Building >> Technical Support >> Schedule or quantity for just demolished walls
Thu, May 13, 2010 at 3:40:57 PM | Schedule or quantity for just demolished walls
pepsiqueen
pepsiqueen Avatar
I search high and low and found no answer. <br>
For a cost estimate i need to know the total amount (in SF) of walls being demolished. i have tried both wall schedules and material takeoffs...and i can't seem to isolate the demolished walls. <br>
i am  using  the default revit phases. <br>
anyone?
I'd rather be riding at whistler. or highland. thats good too.
Fri, May 14, 2010 at 7:22:56 AM | Schedule or quantity for just demolished walls
If you used a demolished phase, I think it should schedule but I have not had to do this.
Wed, Sep 19, 2012 at 1:16:22 PM | Schedule or quantity for just demolished walls
DuncanNZ
DuncanNZ Avatar
You'll need to make a new Phase Filter under Manage > Phasing > Phases > Phase Filters where New and Existing Construction are set to 'Not Displayed'. I've called mine 'Show Demolished'. You can now use this as the Phase Filter for the Schedule making sure that the Phase is the one in which you done the demolition.
Creating a whole Phase for Demolition is not necessary for this issue.
demolished material in one schedule
Tue, Apr 16, 2013 at 4:56:54 AM
Turning off demolished walls
Tue, Apr 11, 2006 at 7:55:05 PM
Revit 2009 - Quantity Take offs
Thu, Sep 9, 2010 at 4:41:22 PM
Is Revit able to do serious quantity surveying stuffs?
Thu, Jan 20, 2005 at 12:03:33 AM
Demolished walls hiding proposed stuff
Tue, Sep 20, 2016 at 5:54:34 PM
Page generation time: 0.4562
