Forums >> Revit Building >> Technical Support >> Lineweights in a floor plan
Wed, Sep 28, 2005 at 10:10:14 AM | Lineweights in a floor plan
scampbell75
Hi everyone, Does anyone know of a way to have different lineweights for interior and exterior walls without using the Linework tool? A client wishes to distinguish between the two and that's what they do in AutoCAD at this time. Sean
Wed, Sep 28, 2005 at 5:17:52 PM | RE: Lineweights in a floor plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not really possible. You could use the host layers override tool in the visibilty settings to set certain layers within a wall to be a different linetype then make sure your interior and exterior walls use the appropriate layers... However, i can't see this working very well as the common edges line will tend to take precedence over most of the lineweights. Unfortunately not possible at the moment. Add it as a wishlist item. It seems feasible given that you can set particular wall types as interior, exterior, foundation, retaining or soffit.
ceiling plan lineweights
Thu, Jul 29, 2004 at 3:53:35 PM
Lineweights Issue
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights Question
Wed, Aug 3, 2005 at 4:03:11 PM
I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
Tue, May 29, 2007 at 1:33:49 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Page generation time: 0.6872
