Forums >> General Discussion >> Wishlist >> Custom Wall Cleanup tool
Thu, May 13, 2010 at 12:02:26 PM | Custom Wall Cleanup tool
ArchAddict
I have an idea for an improved wall cleanup tool, this might be as a second step to the existing cleanup tool but the basic idea is you select a wall intersection like you do now with the wall cleanup tool. Then revit pulls all of the walls back away from the intersection so nothing is joined. Then it gives you a trim tool that selects each component of the wall and let you trim/extend that to any other component of one of the other walls next to it. This way you could select your gyp layer on one wall and trim/extend it to the adjacent wall, then select your mtl. stud and trim/extend it to the mtl stud in a different wall and ultimately make a true custom wall join.
Mon, Jan 18, 2016 at 10:27:49 AM | Custom Wall Cleanup tool
AlderArchitecture
This is a 6 year old post! Any luck in this direction?
Mon, Jan 18, 2016 at 10:33:30 AM | Custom Wall Cleanup tool
ArchAddict
Nope, But HAving forgotten about the entire idea of doing this.. i'll throw it out on the revit Beta forum and see if it gets any traction.. maybe for Revit 2025 :-)
Mon, Jan 18, 2016 at 10:33:39 AM | Custom Wall Cleanup tool
AlderArchitecture
http://www.revitcity.com/forums.php?action=viewthread&thread_id=32535 Oh this is the exact problem I am having. I may have to try this. I'll let you know how it goes.
Mon, Jan 18, 2016 at 10:35:43 AM | Custom Wall Cleanup tool
AlderArchitecture
Thanks ArchAddict!
Mon, Jan 18, 2016 at 11:21:59 AM | Custom Wall Cleanup tool
Make sure you thouroghly understand wall layer priorities.  That may solve your frustrations.
Mon, Jan 18, 2016 at 11:28:44 AM | Custom Wall Cleanup tool
ArchAddict
WWHub is definitely right, having the right priorities is Key, i'd say that 95% of my wall joins are either natually correct or 1-3 variations on the wall join tool... but there is always that other 5% that require getting creative to make it come together.  most of my problems arise at acute angles, or where 3+ walls come together at once. Definitely not the typical case, but frustrating when your under a deadline and you cant even get the wall to look correct.
Mon, Jan 18, 2016 at 2:12:14 PM | Custom Wall Cleanup tool
AlderArchitecture
Okay, I see on the wall composition where the priorities are set up.  Makes perfect sense when joined two walls with different layers.  Thanks.  Still a good idea up above because the wall clean ups aren't great at angles or difference wall materials.
FYI, I also resolved my issue.  Just using the wall join tool, I had to click the miter button from the Butt button.  Cryingsay that anywhere but here, HE-He-He!)  MMMM, I think Facebook needs a Butt Button!
Okay, thanks all, great advice.  Back to work!
WALL JOIN CLEANUP TOOL
Tue, Aug 16, 2011 at 2:41:10 AM
Wall Floor Intersection Cleanup
Thu, May 4, 2006 at 12:06:45 PM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008
Wed, Sep 3, 2008 at 12:33:09 AM
Wall Cleanup/Join
Tue, Jul 24, 2012 at 9:46:48 AM
wall cleanup radius
Thu, Aug 9, 2007 at 4:56:14 PM
Page generation time: 3.3127
