11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> monolithic stairs
2 Posts No Rating |
does anyone know how to change the slab thickness on a monolithic stair on revit structure 2010?
I don't work in Structural but try to change the "Tread Thickness".....
try the various thicknesses, stringer thickness I think
I tried modeling monolithic stairs using the stairs tool, but with limited success. I am sure it can be done, but I was having difficulty creating a riser profile to suit what I needed. What I ended up doing instead was creating an in-place family which in the end was much easier to work with for what I needed.
You never ask about Risers in a monolithic stair, your first question was and I quote "does anyone know how to change the slab thickness on a monolithic stair on revit structure 2010, if you ask about risers in a monolithic stair we had told you need to create that in a in-place family with a categorie "generic Model" because in-place don't have "Stairs" in his categories..
" You never ask about Risers in a monolithic stair, your first question was and I quote "does anyone know how to change the slab thickness on a monolithic stair on revit structure 2010, if you ask about risers in a monolithic stair we had told you need to create that in a in-place family with a categorie "generic Model" because in-place don't have "Stairs" in his categories.. " Ty, the first question was not made by pdoug but by nojin.....
OMG.... I had not noticed.. sorry Nojin...
Can't create monolithic stairs (Revit 2013, beginner) |
Fri, May 27, 2016 at 11:21:56 AM
monolithic stairs |
Thu, Mar 15, 2012 at 11:34:58 PM
Wrapping stairs |
Thu, Aug 12, 2010 at 5:27:02 PM
Monolithic stair PROBLEM |
Sat, Feb 9, 2013 at 8:14:32 AM
monolithic stair join at floor slab |
Wed, Sep 24, 2014 at 11:30:35 AM
