Forums >> Revit Building >> Technical Support >> walls not visible on floor plan
Wed, May 12, 2010 at 2:31:31 PM | walls not visible on floor plan
sudanhafif
Hi I draw walls on floor plan but they are not visible. View range  window numbers are  as such in the attached file.
This settings seem to work on other projects but it does not work on thiis current project. Waht else should I  check?Walls are on in visibility graphics of floor plan. I checked Phasing settings, everything seems fine on that one as well. PLease help, I am a newbie.
 thanks
Sudanhafif
Thu, May 13, 2010 at 2:49:29 AM | walls not visible on floor plan
Kardiff
5 Stars: 3 Votes
Check your wall top and base are within where you want them,Also go into your visibility/graphics override and make sure walls are ticked onand press the lightbulb on the bottom of your screen to make sure it isn't hidden in the view
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Thu, May 13, 2010 at 7:20:15 AM | walls not visible on floor plan
coreed
coreed Avatar
4 Stars: 16 Votes
if you are getting pop-up that says they are not visible, the check your base offset in the properties dialog.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Floor Slab not visible in Plan!
Tue, Nov 9, 2010 at 1:58:17 PM
Framing Plan and floor visibility questions
Mon, Sep 8, 2008 at 1:36:00 PM
invisible object on floor plan
Fri, Jul 30, 2010 at 8:07:11 PM
Stair visible through floor
Thu, Feb 5, 2009 at 5:21:21 PM
Ceiling tags: how can i make them visible in floor plan views
Thu, Dec 6, 2012 at 3:59:35 PM
Page generation time: 0.8924
