Forums >> Revit Building >> Technical Support >> What happen to the material properties in Revit 2011
Tue, May 11, 2010 at 8:04:19 AM | What happen to the material properties in Revit 2011
albertstwrt
4 Stars: 8 Votes
Can someone tell me how to change wood materials in Revit Architectural 2011? I have a wood material on file that I need to use in a project.........
Tue, May 11, 2010 at 8:52:27 AM | What happen to the material properties in Revit 2011
4 Stars: 205 Votes
Albert I don't have Revit here to show you with an image but i think you gonna understand... after you select a material>duplicate then in Render appearence click on the image, then you can select the folder and the file (image...) of that new material you want to apply....
Tue, May 11, 2010 at 9:40:46 AM | What happen to the material properties in Revit 2011
This was a little harder to find then in 2010...look at attached image
  • This is in your HELP
  • Create a new material name by copying something close and renaming
  • Under manage / materials, replace the ender appearance using something similar to what you want
  • To use a new image file, click on the image and the texture editor comes up
  • Click on the source and it will turn color and you can search for a new image file
  • You do a similar process for the bump file if you need it.
Revit 2011 Hang on Material Painter
Thu, May 27, 2010 at 7:50:17 AM
Revit 2011 Properties box
Wed, Dec 8, 2010 at 8:45:57 AM
Same material looks different when rendered Revit 2011
Sun, Jan 2, 2011 at 8:12:10 PM
Duplicated materials taking on same properties
Thu, Jan 21, 2016 at 1:49:03 PM
2011 revit: selected material/color does not show up
Tue, Jun 8, 2010 at 3:41:55 AM
Page generation time: 2.6012
