Forums >> Revit Structure >> Technical Support >> Column Splices
Tue, May 11, 2010 at 7:23:05 AM | Column Splices
TonesMartin
Part way through project and we want to add splices.  We did so by creating duplicate columns in the same place and then dropping the top of one set and raising the base of the other.  This was in an attampt to retain the connectiviy of the framing already created.  It was reasonably successful except the pile caps were attached to the ones with the bases that moved - bit of a job to reset them because of the many levels the caps were at.
 Does anyone have a good reliable work flow to do this so the information created is not lost?
Showing splices in graphic column schedule
Fri, Nov 20, 2009 at 9:05:15 AM
Beam splices
Fri, May 25, 2007 at 2:56:49 PM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
L shaped column
Mon, Jun 22, 2015 at 4:37:29 AM
Page generation time: 1.1004
