Forums >> Revit Building >> Technical Support >> Just an Advice...
Mon, May 10, 2010 at 7:47:30 PM | Just an Advice...
coske
Hey guys how r you Smile
I got little dillema and ihope some of your will be able to simplify it a little bit...
im starting new project today, and its 250 unit complex, with 25 townhouses...out of those 25 townhouses there are 7 different types of them...
 so question is...would it be more practical to create central file, as site plan, and link townhouses in it, so that way i have the freedom to change the levels of the townhouses, add step downs and so on...
 or other option...linking them...
 i know how to do both, but it seems that sometimes one option is more applicable than other...or easier...and i just thought, better ask, then start the whole thing on the wrong way...
 thanx heaps for ANY advice....Smile
Tue, May 11, 2010 at 7:51:43 AM | Just an Advice...
I would create a seperate site project and link the site into individual townhouse projects.  Depending on the number of townhouses, you may not want to link them all back into the site but instead use a simple Group to represent the units in the site.  No need for all the building data in the site.
Tue, May 11, 2010 at 6:28:38 PM | Just an Advice...
coske
thanx WWHub...
its preety much the opposite of wat i thought...just to put it in simpleton terms...
1 - create site with toposurface
2 - link it in each townhouse file - that will give me everything i need for working drawings...site plan and location plan...with FFL's proper sections and elevations...
 now if i want 3D of whole complex...i would have to link simple versions of model back into site...meaning create new file...which would be 3D Model only...
 cause if i want simple files...wouldnt i have to duplicate the townhouse files and gelete all unnecessary stuff in it...
im sorry, but now im preety much as confuzed as u can get...
Wed, May 12, 2010 at 7:31:38 AM | Just an Advice...
You wrote: ..."1 - create site with toposurface" - correct
                ..."2 - link it in each townhouse file - that will give me everything i need for working drawings...site plan and location plan...with FFL's proper sections and elevations..." - correct
..."now if i want 3D of whole complex...i would have to link simple versions of model back into site"  You can use the whole unit model - depends on their size.  But if you are going to render the site model with all the units, the contents of these units can create problems.
We like to place the exterior faces of our models (exterior walls, windows, doors, roof) into a "shell" workset so that they can be viewed (or copied) separately from everything else.
Sun, Sep 12, 2010 at 6:55:38 PM | Just an Advice...
coske
even though i have started this tread a while back, i have created worksets for few designs we have...
now, issue i got is once u enable worksets, u create central file...yara yara yara...all good, but what  i DID OVERLOOK is that the designs we use we repeat, i work for project builders, and they have their 'standard designs' which get overly repeated...its colour schemes that are different...
because of that...once i load external shell into new project (site layout), i cant paint it, i would have to go back into central file, and modify the colour scheme, to load the same building in the site, but with diferent colour scheme...but then im modifing central file, in itself, and i dont think thats the idea of worksets...
in that case, im thinking...would u set the worksets in "standard designs" first...OR...you would copy the standard at the biggining of each project, and then create the colour scheme, enable worksets, and so on,  and THEN import the copied file into site plan, and model it...
 hopefully the above written does make sence...
Sun, Sep 12, 2010 at 9:07:20 PM | Just an Advice...
coske
i answered my own question...for anyone else out there...wat i workd out and it seems like it works for us is
1)     make central file - enable worksets on network drive
2)     copy central file to local machine - create local file
3)     open the file via 'R-Open-"select local file & select option DETACH FROM CENTRAL"-open'
4)     result is modifiable file which i can import into site plan, and disable and enable worksets
 if anyone knows a better way...let me know
 regards
Advice from Professional Architects/Architectural Technicians
Wed, Apr 20, 2016 at 4:47:25 PM
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:03 PM
Advice - Wall Cornice
Fri, Feb 3, 2012 at 12:05:51 PM
Multiple Building Project. Need advice.
Tue, Oct 13, 2009 at 10:28:32 AM
counter top with custom profile edge --advice needed
Fri, Dec 10, 2004 at 9:21:26 AM
Page generation time: 1.7748
