Forums >> Revit Building >> Technical Support >> Surface Nodes. Help.
Sun, May 9, 2010 at 3:50:41 PM | Surface Nodes. Help.
Mixaeel
Mixaeel Avatar
When you divide a surface on vertical and horizontal lines, and you make your nodes visible. Nodes as the spots on the grids intersection. You dont have the same ability as with the nodes called Vertex on the corners of the surface.
What I would like to know is there any way, to make surface nodes selectable (therefor movable) as the vertexes? Look at the images
Any help is appreciated
Michael
Mon, May 10, 2010 at 3:55:51 AM | Surface Nodes. Help.
4 Stars: 205 Votes
I think you should watch this: http://buildz.blogspot.com/2010/03/look-ma-no-api-rule-based-form-creation.html
conical spirals
Thu, Jun 7, 2012 at 4:50:24 AM
linework nodes in section
Thu, Oct 16, 2008 at 8:53:07 AM
Revit and Render Nodes (farms)
Thu, Jul 24, 2008 at 3:22:06 PM
Repeat Adaptive Component to a Surface
Thu, Dec 4, 2014 at 6:22:18 AM
Linework Tool nodes and adjustments
Wed, Sep 7, 2011 at 6:27:02 PM
Page generation time: 1.7737
