13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> text box leader alignment
17 Posts No Rating |
I was always under the impression that the size of the text box is somehow defaulted to fit around the text defined by system parameters. the attached image might suggest otherwise. aside from line weight, both highlighted text elements have identical parameters in the "type properties" box. why is one box bigger that the other. each box allows for only line of text.
What "the attached image might suggest otherwise" ???
as Typhoon said what "attached image". we were under the impreession that their was an attached image. there could be many reasons why it is not attached. as for text, when you are starting to place text and just click to define a starting point, not dragging to define a text box, the text box should default to fit around the text entered. is this problem happening when you are placing text?
Distance from leader to text... Revit 2010 |
Tue, Jun 1, 2010 at 9:13:51 AM
keynote text and leader alignment |
Thu, Aug 19, 2010 at 8:56:10 AM
Multiple Leader Text |
Sun, Nov 18, 2007 at 12:33:40 PM
CHANGING SIZE OF DIMENSION TEXT BOX |
Wed, Feb 25, 2009 at 4:22:17 AM
ARC LEADER NO TEXT |
Thu, May 2, 2013 at 10:36:04 AM
