Forums >> Revit Building >> Technical Support >> Doors interfering with each other between phases
Fri, May 7, 2010 at 12:43:28 PM | Doors interfering with each other between phases
NDArchi03
I am new to Revit and am working on my first project.  I have phasing set up but am having problems with new doors and demo'd doors interfering with each other.  We are demo'ing an old door and replacing it with a larger new door.  When I go to place the new door I get an error and either can't place the new door or I have to delete the old door.  This seems like a a major flaw in the phasing system and can't believe that there isn't a way to do it.  I have looked through the Revit help file, AutoDesk's Knowledge Base, and RevitCity forums but can't find anything.  Any help would be appreciated.
Fri, May 7, 2010 at 12:51:09 PM | Doors interfering with each other between phases
The problem is probably caused by revit wanting to fill in the demo'd opening and your new door wanting to remove that.  I think Revit does need an option to just remove a door / window and not fill in the opening.
I have not run across this problem but I could get around it visually by using design options.
Phases and Schedules
Thu, Aug 26, 2010 at 1:31:11 PM
Phasing is interfering with Room Area/Tags (I think)
Wed, Sep 28, 2016 at 1:15:48 PM
2020 revit - doors not recognizing rooms in a phased project
Thu, Feb 13, 2020 at 9:52:26 AM
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:02 AM
Demo Plan with multi phases
Tue, Jul 28, 2015 at 7:34:43 AM
Page generation time: 1.8201
