Forums >> Revit Building >> Technical Support >> SLOPING CAST STONE WINDOW SILL APPLICATION
Fri, May 7, 2010 at 12:13:28 PM | SLOPING CAST STONE WINDOW SILL APPLICATION
burko
I have tried applying a cast stone window sill with a sloping profile as a sweep to a brick veneer wall.  The sweep shows up fine when I look at it in section view - the brick is part of the wall structure and still extends to the window frame.  In other words there is a portion of wall still seen at the sloping portion of the sill.  What is the best procedure to remedy this? Thanks for any help.
Sat, May 8, 2010 at 11:42:30 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
4 Stars: 205 Votes
Can you put here some screenshots in section and 3D view so we can look what is the real problem?
Sun, May 9, 2010 at 12:04:44 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
ya im not sure what you mean, as typhoon said put some pics up, it sounds like a easy fix.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, May 10, 2010 at 8:43:28 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
burko
I have attached a screen shot which shows the condition.
Mon, May 10, 2010 at 9:09:10 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
burko
Since I blew the first attempt - here is the condition.
Mon, May 10, 2010 at 9:15:39 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
burko
Here is a 3D of the window sill.
Mon, May 10, 2010 at 9:17:48 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
4 Stars: 205 Votes
Create a "Void" in a In-place Family in the category "Walls" to cut that portion of wall...
Wed, Feb 27, 2013 at 10:42:01 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
Rabi
Replace the wall opening cut with a void extrusion on the window family. Revit won't allow you to have opening cut and void extrusion in the same family. Thus your wall cuts need to be based on void extrusion. I hope this helps.
Thu, Feb 28, 2013 at 8:38:42 AM | SLOPING CAST STONE WINDOW SILL APPLICATION
matthewh75
3 Stars: 3 Votes
Alternatively create a hosted wall family for the cill that has a void in it. This would also allow you to schedule the item easily.
I hate wall sweeps.
cast stone sills in Revit 2010
Tue, Jun 29, 2010 at 3:31:21 PM
CAST STONE HEADER OVER A WINDOW
Mon, Nov 23, 2009 at 7:53:32 PM
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Arched window with stone arch above it? How to do it?
Wed, Apr 13, 2005 at 2:22:57 PM
Window with angled sill
Fri, Nov 16, 2012 at 10:49:57 AM
Page generation time: 0.2160
