9 Users Online (8 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM | Project North doesn't rotate back after changed to True North
JohanEkstrom
I've got a weird little problem...or a big problem actually...
I've started drawin' walls in Project North and set the True North with a linked Cad with Acquire coordinates. When I change the parameter in View Properties to True North, the view rotates properly. So far so good. But when I change again back to Project North, nothing happens! The view stays in True North although I switched it back to Project North.
This is drivin' me nuts... :o) Any thoughts? Ideas?
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
rotate PROJECT north (not true north)
Wed, Jun 10, 2009 at 9:11:40 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
True north help
Tue, Jul 21, 2015 at 3:52:04 PM
rotate true north
Wed, May 21, 2008 at 9:21:13 AM
Page generation time: 1.2698
