Forums >> Revit Systems >> Technical Support >> TOPOSURFACE
Thu, May 6, 2010 at 10:03:37 PM | TOPOSURFACE
Lilian2009
I'm struggling..can someone direct me to a video on simply toposurace. i've done my contours but now i need to get it graded for basement, crawlspace and garage sog. help
IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP.
Fri, May 7, 2010 at 2:03:11 PM | TOPOSURFACE
4 Stars: 205 Votes
Can you elaborate your question please? "i've done my contours but now i need to get it graded for basement" You have done your Contour in what software? Revit? Civil?? How? Do you want to create a PAD to create a "Basement" in your building???
Fri, May 7, 2010 at 10:57:17 PM | TOPOSURFACE
Lilian2009
Thanks Typhoon.
I'm using Revit Architecture 2009. I've done the contours using the points [yes, I have the z calculated for each point]. Because the house is on a slope, I have started with created levels - basment level, crawlspace , ground level top of wall and roof level. I've drawn the foundation walls with bearing footings and slab using the Structural/Foundation wall and slab tool. Through thi sprocess, i find it really time consuming but I tried to do it as if I am building from ground up. I don't seem to be able to do it from plan so I use the section tools to help me to move the slab and foundation wall. I don't know if there is a faster and smarter wall of doing that. Also, I don't udnerstand what is the pad, sub region different from each other and how is that different from the slab. I wish there is a video tutorials on toposuface so I can learn.
Lilian
Sat, May 8, 2010 at 7:52:24 AM | TOPOSURFACE
4 Stars: 205 Votes
I gonna create a video for you because i think an Image worth more than a 1000 words... BUT you must use your HELP menu and the Tutorials to learn more about this....
Ok, watch this: http://www.megaupload.com/?d=2CMH8TS3
Edited on: Sat, May 8, 2010 at 8:10:19 AM
Sat, May 8, 2010 at 1:19:22 PM | TOPOSURFACE
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
The link is suspended Ty
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Sat, May 8, 2010 at 1:22:29 PM | TOPOSURFACE
4 Stars: 205 Votes
it's working, try it again...
Sat, May 8, 2010 at 1:25:28 PM | TOPOSURFACE
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Nevermind it worked at the end
Sat, May 8, 2010 at 3:35:30 PM | TOPOSURFACE
Lilian2009
Thanks Typhoon. I've downloaded the file PAD.rar but what's application is that?  I can't open in quick time, media, etc.
Lilian
Sat, May 8, 2010 at 9:30:54 PM | TOPOSURFACE
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
USe internet explorer or firefox for the other format swf I think or flv you guess
Sat, May 8, 2010 at 10:11:13 PM | TOPOSURFACE
erland73
erland73 Avatar
4.5 Stars: 85 Votes
" I can't open in quick time, media, etc."....weird, I could open that .mp4 file using WMP, VLC, Quick Time & Real Player. The other  file (.swf), is the same video but you can open it with Flash Player or Haihaisoft Universal Player.....
Edited on: Sat, May 8, 2010 at 10:12:05 PM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 1.6366
