Forums >> Revit Building >> Technical Support >> How to Create an isometric/3d view specific to a single Floor
Thu, May 6, 2010 at 8:36:50 AM | How to Create an isometric/3d view specific to a single Floor
JonathanRevit4
Is there any way to create a 3d view for say the first floor without seeing the 2nd and 3rd floor above. In other words is there any way to hide the entire 2nd and 3rd floor above it.
Thu, May 6, 2010 at 8:53:37 AM | How to Create an isometric/3d view specific to a single Floor
In your 3D view, open View Properties, turn on the section box, then adjust the box in that view.
Thu, May 6, 2010 at 12:48:38 PM | How to Create an isometric/3d view specific to a single Floor
TomDorner
4.5 Stars: 25 Votes
Another way is to orient your 3D view to another view.  To do so go to the 3D view, in 2010 and later right click on the 3D view cube, select "Orient to View", choose the floor plans and select your first floor.
This will automatically place the section box in the 3D view sized to the crop boundry of your floor plan in the x,y direction and for the z it will work with the view range you set for the plan with respect to top and bottom.  This is where the top of a floor plan cut range starts to make sense.  By default it is set to 7'-6", but I set it to level above with a negative offset that removes the thickness of the floor above out of the view.
You can also use the orient to view with, sections, callouts, elevations.  My theory is that most Revit users are severely lacking in 3D views for their project.  I would expect a 100,000 SF building to have 100's of 3D views.  Some would be 3D details for the documentation set, others would be used for you the modeler to understand and model efficiently.
HTH
Tom
Thu, May 6, 2010 at 2:42:46 PM | How to Create an isometric/3d view specific to a single Floor
JonathanRevit4
Thanks a lot to both of you. I figured it out.
Thu, May 6, 2010 at 3:09:27 PM | How to Create an isometric/3d view specific to a single Floor
coreed
coreed Avatar
4 Stars: 16 Votes
WOW Tom, 100's of 3d views. oh by the way, Welcome Back
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 6, 2010 at 3:48:50 PM | How to Create an isometric/3d view specific to a single Floor
TomDorner
4.5 Stars: 25 Votes
Thanks coreed.  Got lots of time to hang around here since I got laid off from Autodesk at the end of February.  At least the questions keep me focused on Revit and in the game while I look for a new job.
I've been to a lot of different firms over the past three years, and the lack of view created on most projects is clearly a problem.  Too many people think that the view only exists to be part of the CD set.  My rule of thumb is at least one additional "working" view for every printed view.  Also, we are in a 3D world in Revit so why not make that part of your CD set?
Tom
ISOMETRIC VIEW, 2009
Tue, Aug 26, 2008 at 3:50:51 AM
Revit doesn't show Autocad isometric drawings
Thu, Nov 27, 2014 at 10:27:03 AM
can the camera be set to give a perspctive view instead of isometric
Mon, Apr 23, 2012 at 8:46:48 AM
Isometric Views & Scale
Fri, Aug 20, 2010 at 11:18:07 AM
viewing areas in 3D or isometric view
Tue, Sep 6, 2011 at 10:06:09 AM
Page generation time: 2.3365
