Forums >> Revit Building >> Technical Support >> viewport tags
Thu, May 6, 2010 at 8:28:26 AM | viewport tags
vblevin
Where/how the heck do I change the parameters of the viewport tag (like font style and size)? I did it once before and dont remeber how.
Thu, May 6, 2010 at 8:51:27 AM | viewport tags
You have to edit the view title family.
Thu, May 6, 2010 at 8:58:33 AM | viewport tags
vblevin
 How do I do that to an existing viewport? I dont see an option to edit the family.
Thu, May 6, 2010 at 9:07:49 AM | viewport tags
Viewport Titles are families... Look in your browser
Read this in your HELP..
  • "Creating a Viewport Type"
  • "Applying a View Title Type to a Viewport Type "
Thu, May 6, 2010 at 9:21:40 AM | viewport tags
vblevin
I always look in "help" before asking in the forum. But sometimes its like trying to find a needle in a haystack. Can anyone else give me the 'quick' answer.  Thanks in advance.
Thu, May 6, 2010 at 3:18:49 PM | viewport tags
rev2010
vblevin, just in case you haven't found your way,
file-open,
look in: imperial library / annotation / view title.rfa,
mess up the family anyway you want, save it as a different name, load it into your rvt model,
right click - element property - edit type - duplicate - graphic, select the new Title, then OK 2 times.
the idea is not to allow people mess up your office standard randomly, CAD people can waste all day changing text sizes from 3/32 to 5/64, hey how about 13/254, then line color, weight, style, etc that has absolutely no meaning in design or documentation work.
OR, you can right-click on the view - hide view (parametric view title will disappear), then back to 2D CAD drafting mode and customize the view title.
how to erase Viewport Tags
Wed, Jan 7, 2009 at 9:14:36 AM
Viewport larger then needed on sheet
Tue, Feb 20, 2007 at 10:38:25 AM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
viewport annotation box
Mon, Jun 2, 2014 at 8:49:40 AM
Is their a way to change the Viewport referencing?
Wed, Sep 21, 2016 at 3:16:25 PM
Page generation time: 2.5152
