Forums >> Revit Building >> Technical Support >> Importing General Notes
Wed, May 5, 2010 at 11:19:48 AM | Importing General Notes
svasilion
I'm using Revit 2010.  As a relatively new Revit user I'm trying to figure out how to best import or duplicate things like General Notes, General Specs, etc. from Autocad into Revit.  I'd like to have them available in my library for repeated use, and also placed into my project templates.
Thanks!
Wed, May 5, 2010 at 11:26:59 AM | Importing General Notes
Put the text into legends.  You can copy those between files.
Wed, May 5, 2010 at 11:59:36 AM | Importing General Notes
svasilion
I opened up an Autocad drawing, highlighted a block of text (General Notes), then tried pasting them (Ctrl-C) into a newly created Legend.  Nothing seems to have happened.  What step(s) am I missing?
Wed, May 5, 2010 at 1:26:49 PM | Importing General Notes
TomDorner
4.5 Stars: 25 Votes
You need to paste them into a text box in Revit.  Copy the ACAD to clipboard, then start the text command in Revit, then CTRL V to paste.
Tom
Wed, May 5, 2010 at 2:29:26 PM | Importing General Notes
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
You can also import them lt like a cad file then explode in revit or leave it just like a block
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Wed, May 5, 2010 at 2:44:01 PM | Importing General Notes
4 Stars: 205 Votes
Don't do that Carrucha, do it just like Tom and WWhub said, simple, copy/paste, nothing more....
Wed, May 5, 2010 at 3:23:38 PM | Importing General Notes
svasilion
Thank you... that worked just fine.  Next question: the text is one continuous column.  What is the easiest way to break it into multiple columns?  In ACAD I'd just create multiple vports.
Wed, May 5, 2010 at 3:29:25 PM | Importing General Notes
Not sure what 2011 has to offer here but there are some more text editing options.  We just do multiple text windows.  I try to make sure though that each column is one window... in other words it has paragraph returns, not multi text boxes stacked.
Wed, May 5, 2010 at 4:19:53 PM | Importing General Notes
svasilion
Are you saying that for example, if I want my General Notes to appear as five columns of text, my General Notes legend would then have five text windows, one for each column of text?
Wed, Feb 9, 2011 at 8:08:29 PM | Importing General Notes
tectacoma
tectacoma Avatar
Yeah it finally worked...
Edited on: Wed, Feb 9, 2011 at 9:25:48 PM
creating General Notes (best practices/ efficient methods) 2017
Fri, Nov 17, 2017 at 4:37:25 PM
Typing General Notes
Mon, Sep 20, 2010 at 1:32:39 PM
General notes & vent calcs
Tue, Oct 11, 2005 at 6:15:04 PM
justification problems creating general notes.
Mon, Sep 21, 2015 at 9:24:19 AM
Adding a General Notes section to our model spashscreen
Thu, Jun 13, 2013 at 10:03:02 AM
Page generation time: 0.5949
