25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> HELP..text relocating....project due
22 Posts No Rating |
Of course this project is supposed to go out tomorrow and WHAM, my text has disappear only to have some re-appear in another drawing within the file. Any idea what happened? The latest back-up file I have contains the same problems. I could really use some advice on how to either get the text back to the correct drawing location or find a hidden back-up file.
Thanks for any advice...as long as its good.
interesting, I never had this problem... text is view specific, so I can't see how it got to other views(?)
the best thing is to send the file to the factory for them to look at it, tell them it's urgent! use buzzsaw.
goodluck!
36 Posts No Rating |
don't you have daily backups? go to an older backup, and pull off what you can.
Thanks for the advice...
Autodesk is trying to figure this out. This project had a lot of text imports (schedules) which were exploded and I then changed the text and lines to revit properties. The text is still shifting and the thin lines (not the medium or wide) sometimes get relocated.
I setting a sheet up and printing because it will be different when I re-open the drawing.
Who knows?
Emergency Help Due Monday ! |
Wed, Jun 14, 2006 at 4:54:27 PM
Relocating Project |
Fri, Jun 4, 2010 at 10:57:27 AM
Annotations, Labels or Tags |
Wed, Aug 25, 2010 at 2:42:26 PM
keynote text size wont match text size of project with same parameters |
Mon, Nov 27, 2017 at 10:26:54 AM
signage text |
Thu, Feb 12, 2009 at 2:05:02 PM
