Forums >> Revit Building >> Technical Support >> dimension tick
Wed, May 5, 2010 at 4:35:20 AM | dimension tick
durgeshbrijwasi
is there any way by which i can change the parameters of the tick of dimension line....can i introduce a new type of tick for dimensioning.....
Wed, May 5, 2010 at 4:40:45 AM | dimension tick
durgeshbrijwasi
in revit 2010
Wed, May 5, 2010 at 8:08:41 AM | dimension tick
You can change the type of trick from a few standard choices and you can modify the size and lineweight.
Dimension with Tick and Dot
Fri, May 21, 2010 at 10:36:20 AM
Dimension tick mark
Mon, Jul 11, 2005 at 2:31:38 PM
Dimension Tick Resize
Fri, May 12, 2006 at 11:50:56 AM
Dimension with both dot & tick
Mon, Jun 26, 2006 at 10:37:15 AM
DIMENSION TICK MARKS
Tue, Mar 20, 2007 at 6:55:23 PM
Page generation time: 0.1062
