Forums >> Revit Building >> Technical Support >> REVIT 2010 - Section Cut Detail Mark & View Range
Tue, May 4, 2010 at 11:29:34 AM | REVIT 2010 - Section Cut Detail Mark & View Range
grwilliams
We have a situation where a section cut detail mark placed in a plan view is not showing up with the view range top set to the standard 7'-6".  When we chage the top region to 9'-0", the section cut detail mark shows up.  Shouldn't these symbols show up in the plan view regardless of view range settings or is it similar to the interior elevation markers that need to have the upper range adjusted in order not to show up on multiple floors?  Any response on this issue will be greatly appreciated.
Thanks in advance,
G Williams
Gregory Williams, AIA, LEED AP
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:20 PM
Section cut disappears when I change the view range in plan view.
Tue, Oct 28, 2008 at 3:50:07 PM
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:11 PM
14
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
View Range problems- seeing wall detail
Fri, Jun 6, 2008 at 8:56:57 AM
Page generation time: 1.9872
