Forums >> Community >> Newbies >> embed other file formats (e.g. pdf) in components
Mon, May 3, 2010 at 12:38:13 AM | embed other file formats (e.g. pdf) in components
f11m
Hi,
I'm currently using Revit Architecture 2009. The only way I can embed other files currently is if I upload them on the web, and hyperlink them in the URL (identity parameter). Is there any way I can 'hyperlink' pdf or excel files from Revit components to files within my computer, even when there's no internet connection? I tried but nothing opens if it's not online.
I'm asking this because I would like to try using the 3D model as a 'map' to find other data. Thanks in advance!
Mon, May 3, 2010 at 7:18:42 AM | embed other file formats (e.g. pdf) in components
You are using th URL parameter under type properties I assume.  You can use this same parameter for mapping to a file on your system - just put in the complete path.
Wed, May 5, 2010 at 1:56:08 AM | embed other file formats (e.g. pdf) in components
f11m
Thanks, it worked. My silly mistake - used the wrong url.
How to print different sheet formats in PDF?
Mon, Jun 5, 2023 at 2:07:16 PM
Importing 3D components created iin other file formats?
Wed, Dec 6, 2006 at 3:47:44 PM
printing large formats in pdf
Thu, Dec 29, 2011 at 6:25:11 PM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
Can you change a rvt file type to pdf?
Tue, Jun 25, 2013 at 2:30:12 PM
Page generation time: 0.5104
