Forums >> Revit Building >> Technical Support >> Complex roofs
Sat, May 1, 2010 at 6:48:56 AM | Complex roofs
EssG
Revit 2009 Arch
Hi,
How do you do a hip roof that has a skillion  faces blending into it
I have tried  using the same method that you use to do a dutch gable but end up with holes all over the place and the ridge lines moving to middle of new position.
Plan/elevation Files (done in 2D cad) attached
Any help greatly appreceated.
Thanks
EssG
Thanks
Sat, May 1, 2010 at 7:22:51 AM | Complex roofs
skillion - was a term I had not heard before.  We just call them shed roofs.
I usually model these as two seperate roofs and I would edit the sketch profile of the shed where it is over the main roof since this is an over-build condition.  To do this, use a rectangle at first and finish the roof then join them.  Now you can place a reference line at the junction to use and edit the shed roof.
Sat, May 1, 2010 at 7:23:41 AM | Complex roofs
EssG
Sorry..last image done in Revit, and show how roofline turns out.
Thanks
Sat, May 1, 2010 at 7:31:33 AM | Complex roofs
EssG
Smile..shows the different names for construction in different countries (Australa for me)
 Back to the problem....I have done them as seperate roofs -  Main roof first and then the "Shed".
 Part of the main roof has to be edited out (under the shed roof) and then part of the Shed has to be edited out where it joins the main roof...and no matter how I try to edit them I end up with holes and my ridge line over the front (where the two window are) moving to the center of that wall width (the new possion for the edited main roof) so I end up with Pic three instead of pic 1 front elevation
It has me totally stumped
Thanks
Sat, May 1, 2010 at 8:20:28 AM | Complex roofs
4 Stars: 205 Votes
Ok, watch the video: http://www.megaupload.com/?d=CIPKG9H9
Sat, May 1, 2010 at 9:45:26 PM | Complex roofs
EssG
Typhoon, you are Fantastic!!!!!!!.
Thanks for your time and effort. I've learned a lot and it was MOST usefull
Cheers
Essie
Sun, May 2, 2010 at 5:43:09 AM | Complex roofs
4 Stars: 205 Votes
I'm glad you have learned something with the video...
Sun, May 2, 2010 at 8:38:53 AM | Typhoon
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Typhoon from 2010-05-01 08:20:28
What happen to JING
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, May 2, 2010 at 10:03:11 AM | Complex roofs
4 Stars: 205 Votes
LOL... I have the Jing Pro too you know that, but this time I use the Camtasia, only to change...
Sun, May 2, 2010 at 10:11:04 AM | Complex roofs
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"....but this time I use the Camtasia, only to change...", Shiny  ....cool "funzy"...
Edited on: Sun, May 2, 2010 at 10:12:38 AM
Dormers on complex roofs
Tue, Sep 20, 2011 at 11:11:37 AM
Complex roofs for high end residential projects
Wed, Oct 10, 2018 at 2:10:11 PM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Revit Benchmarking
Wed, Mar 22, 2006 at 5:07:01 PM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Page generation time: 0.1423
