Forums >> Revit Structure >> Technical Support >> Materials in a camera view
Fri, Apr 30, 2010 at 5:32:19 AM | Materials in a camera view
Daveybdab
Hi there.
I have been working on a project in revit. The guy that set up the model has since left the company. When I create a camera view and render it all of my masonry comes out as grey rather than having the brickwork effect. If i render from a normal 3d view the materials seem to work fine, its just in the camera view I can't get the materials fo work. I am wondering if anyone has come accross this before and how i can turn on the materials in a new camera view.
Thanks for any help you can offer me.
Fri, Apr 30, 2010 at 6:19:17 AM | Materials in a camera view
4 Stars: 205 Votes
Can you show us images with the render in 3D view and another with the camera view??, Did you try to delete that camera view and create a new one and check if render fine?
Fri, Apr 30, 2010 at 6:45:31 AM | Materials in a camera view
Why not run a test by creating another camera view and rendering from that?  Not sure what could be set differently.
Wed, May 5, 2010 at 7:14:51 AM | Materials in a camera view
Daveybdab
Thanks for the reply guys. I have attached 2 jpegs, one taken from a camera view, the other from the standard 3d view. As you can see the brick material has only rendered in the standard 3d view. One possible thing that might be relevant, the walls are existing masonry and as they are non-standard we had to draw them witht the 'model in place' function choosing 'walls' for the type of model. Any ideas?
Wed, May 5, 2010 at 7:28:35 AM | Materials in a camera view
Existing? ......Are you using phases...?  Tell us the whole story please.
Please include images of the VP settings for both views.
Wed, May 5, 2010 at 8:59:10 AM | Materials in a camera view
Daveybdab
Sorry for the confussion. Think i have found the solution. changed teh phase filter in the camera view to 'none' and now seems to render correctly.
thanks for your help
Wed, May 5, 2010 at 9:08:34 AM | Materials in a camera view
As you can see, we could have helped you much quicker if you had told us the whole story!
PHASES are often a problem.
Sun, Mar 24, 2013 at 12:12:53 AM | Materials in a camera view
mhamby1
I have been having the same problem. Can you tell me how you changed the phase filters to none please? I found the Phases icon but, I don't know what setting to change in it.
Mon, Mar 25, 2013 at 8:17:41 AM | Materials in a camera view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your phasing is located in your properties.
Materials missing in camera view
Wed, Sep 15, 2010 at 10:33:33 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 1:12:58 AM
Camera lens adjustment
Sat, Sep 9, 2006 at 12:03:58 PM
Camera View not showing demolition lines dashed
Wed, Dec 11, 2013 at 2:24:15 PM
saving 3d view camera angle
Fri, Dec 30, 2016 at 7:16:40 AM
Page generation time: 1.0780
