17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Label Editable by Instance?
Placing a data outlet family into my project.. opening this family to edit, found that the data annotation is its own family..opening this family to edit, where i find the electrical label (currently set to B). Is there settings I can use to make this Label (the letter only) editable in my project (i.e. rotate so that it is always right side up according to the orientation of my plan, move it aside if need to make room for other objects.)
?!?! still trying to figure this one out... most concerned with whether or not it is possible to define the labels rotate in th families instance properties AFTER it has been loaded into my project!?! help!
You have to edit the label family and reload it.
Edit Label Family? I have 3 tags in this family, controlled in instance properties accordign to our firms graphic on where the data devices will be placed: floor, ceiling or wall. Could you take a look at this family, and tell me where in each of the 3 labels i control the "B2's" rotate once Loaded into a projecT?! sorry, i'm Super lost  Thanks a million
As I said, you have to edit the family - not controlled in the project.
GOOD ENOUGH. THANKS
Creating Editable Labels |
Tue, Sep 1, 2020 at 7:05:46 PM
Instance Shared Parameter?? |
Fri, Jul 11, 2014 at 2:49:26 PM
making labels editable |
Thu, Feb 12, 2009 at 1:12:46 PM
Instance Parameter to control another Instance Parameter |
Thu, Jul 22, 2010 at 6:22:48 AM
label arrow and instance parameter |
Fri, Jul 24, 2015 at 7:01:38 PM
