Forums >> Revit Structure >> Technical Support >> Revit to CNC machine
Thu, Apr 29, 2010 at 9:51:24 AM | Revit to CNC machine
chaggas
It's been a long time since I've been on RevitCity, so I apologize if this topic is a repeat.
I've been given a project to research any and all potential companies and software programs that can transfer files from Revit directly to a CNC machine. So far there is MWF (Metal Wood Framing) from SrucSoft. The hiccups that we are running into is that the program only recognizes doors and windows as openings in walls, so any type of opening that we create in the wall needs to be based in a door or window family. Doesn't sound like a big deal, but it doesn't give you much room to stray from a conventional building and we run into basic problems with HVAC openings.
Is anyone else using MWF? Is anyone else using a different program or know of a different program? Anyone else trying to get Revit files to a CNC machine? Any information you may have on this topic is welcome.
Thank you!
Thu, Apr 29, 2010 at 10:23:16 AM | Revit to CNC machine
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I think if I were you I would look at what type of software CNC machinists are using. Most would be a CAM based application in which case, can many can read dxf files. You may also explore the options of ACIS models used in conjunction with some form of model interface. Otherwise...send it to someone using Inventor Smile
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Apr 29, 2010 at 11:29:18 AM | Revit to CNC machine
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Are you doing some 3D machining on your CNC machines? (i.e., probing... 4/5 axis?) if so.... Revit is not the answer for you even though revit is a 3d modeler program... even if you're doing 2d machining i would not suggest Revit for it... coz creating NC programs requires precise lines (no overlapping, or broken lines). If you are in Cabinetry industry check out the "CabinetVision" - it's a CAM 3d modeling software which has the capability to convert the 3d model to 2d-ready for your tool path to be send to your CNC Controller.
 "If you tell the truth, you don't have to remember anything"
Can Revit Unfold 3d objects for 2D CNC processing?
Fri, Oct 19, 2012 at 10:41:12 AM
Revit 2010 on a x64 machine
Thu, May 28, 2009 at 1:33:43 PM
Hypothetical Revit Dream Machine
Wed, Oct 5, 2005 at 12:30:09 PM
Link between Revit and CNC machines
Sat, Jun 8, 2013 at 2:01:02 PM
Automated Ticket MAchine
Tue, Sep 28, 2010 at 7:18:58 AM
Page generation time: 2.9728
