13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> Flattened curves for extrusions?
4 Posts No Rating |
Ok, these things are driving me nuts! Look at all the curves in the attached rendering. They're all flat lines composed into a curve! I've used Revit Arch 2008/2009/2010 and they never did this; now I'm using RevitMEP 2009. Is there a setting somewhere that I can change? Thank you! EDIT-Found the Edit Button. Putting the attachment in the first post as well.
Edited on: Wed, Apr 28, 2010 at 2:49:59 PM
What rendering?
4 Posts No Rating |
You were too quick to reply and I couldn't find the EDIT button, so did a reply: My attachment was barely too big. Here it is in .jpg with the background.
Edited on: Wed, Apr 28, 2010 at 2:49:16 PM
I don't know MEP and Revit also don't "like" to work with small pieces.. BUT what is the Radius of those elements?
4 Posts No Rating |
40" OD, those are 1-1/8" dia bolt holes. I know it doesn't like small components, that's why this is so frustrating, it's BIG. The Hinge Pin across the top is 1" dia.
Edited on: Wed, Apr 28, 2010 at 2:48:42 PM
blending curves |
Mon, Oct 13, 2008 at 12:22:38 PM
Joining extrusions |
Tue, Jul 26, 2022 at 3:58:08 PM
Revit 2018.2 Print to PDF Turning Curves into Polygons |
Tue, Apr 17, 2018 at 12:30:39 AM
Multiple Curves and Angles with Sweep |
Mon, Jun 24, 2013 at 1:34:46 PM
naming extrusions |
Thu, Oct 10, 2013 at 10:00:24 AM
