21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Roof patterns
6 Posts No Rating |
I down loaded the spanish tile roof pattern from Revit City. What is the process to being able to use these patterns. IE when I create a roof system I would like this pattern to be on the finish surface pattern. Or am I not using this system correctly? Thank You
You need to load the pattern into your project or template. Under manage/ settings/ fill patterns
" I down loaded the spanish tile roof pattern from Revit City. What is the process to being able to use these patterns. IE when I create a roof system I would like this pattern to be on the finish surface pattern. Or am I not using this system correctly? Thank You " just a note for future reference, its important to state your Revit version in a question like this due to 2010+ interface change
6 Posts No Rating |
I am on Revit version 2011
6 Posts No Rating |
KenM Sorry for asking for more information, However I am new to Revit and not a computer wizard. Can you give a few more directions as to how get the tile roof pattern so I can use it. IE: type this, go to that. This would help. Thank you Ken
Follow the arrows.............
“Learning never exhausts the mind.” — Leonardo Da Vinci
6 Posts No Rating |
erland 73. Thank you very much. Good instructions. Ken
ROOF HATCH PATTERNS |
Fri, Jan 16, 2009 at 12:05:57 PM
Roof Patterns |
Thu, Nov 26, 2015 at 12:51:32 PM
Roof patterns in Metric units |
Sun, Sep 9, 2007 at 7:31:43 AM
Fill Patterns disappear in Roof Plan |
Thu, Jan 7, 2010 at 2:08:39 PM
on/off fill patterns |
Tue, Jun 26, 2007 at 8:25:13 AM
