Forums >> Revit Building >> Technical Support >> revit crashes when adding picture to page setup
Wed, Apr 28, 2010 at 10:21:33 AM | revit crashes when adding picture to page setup
murphyr
I have edited the standard page to include my own title block but when i try to add a .jpg picture revit crashes?
Wed, Apr 28, 2010 at 11:13:39 AM | revit crashes when adding picture to page setup
coreed
coreed Avatar
4 Stars: 16 Votes
what do you mean by "standard page"?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Apr 28, 2010 at 12:32:07 PM | revit crashes when adding picture to page setup
murphyr
the sheet where you drag the items required to be printed
Wed, Apr 28, 2010 at 2:01:49 PM | revit crashes when adding picture to page setup
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
What Revit Version? Try to convert that image to DXF file ...
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Wed, Apr 28, 2010 at 2:04:24 PM | coreed
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Quoting coreed from 2010-04-28 11:13:39
"what do you mean by "standard page"?"
I guess this is Revit Title block already done by autodesk like the templates lets say right murphy?
Wed, Apr 28, 2010 at 2:31:49 PM | carrucha75
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting carrucha75 from 2010-04-28 14:01:49
"What Revit Version? Try to convert that image to DXF file ..."
you can't convert a raster image to dxf ??, atleast i don't think you can. lots of people add raster images to there title blocks, never heard of that causing a crash. sometimes they won't print. hopefully someone will have some insight to your problem.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Apr 28, 2010 at 2:37:21 PM | revit crashes when adding picture to page setup
4 Stars: 205 Votes
Did you try with other image format (extension) like PNG or TIFF?
titleblock not lined up with page
Fri, Jan 13, 2006 at 1:32:44 PM
Autocad Export - Page Setup Manager
Fri, Mar 27, 2009 at 9:03:29 AM
Texture - adding new into matrial library from picture
Mon, Oct 10, 2005 at 5:51:42 AM
RVT to DWG export page layout settinigs
Fri, May 11, 2012 at 3:31:01 PM
Page Setup
Sun, Jan 13, 2008 at 6:58:28 PM
Page generation time: 1.4093
