Forums >> Revit Building >> Technical Support >> Subcategories and Schedules
Mon, Sep 26, 2005 at 2:57:47 PM | Subcategories and Schedules
Annie376
I have been using subcategories to help further filter certain families in categories. For example, I want to see some specialty equipment on my plan, but not all. I figured this would be a good way to filter toilet accessories in a schedule from say exercize equipment in a schedule. I have not been able to add subcategory as a parameter to the schedule...has anyone had any luck with this
Mon, Sep 26, 2005 at 5:40:22 PM | RE: Subcategories and Schedules
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
unfortunately as you've discovered you cannot filter a schedule by a sub-category. Sub-categories are designed merely as a graphic filter in plans rather than for schedules. You would need to add a parameter (i tend to use a yes/no parameter) to the schedule for something like toilet accessory... Then hide this column in the schedule and filter it by toilet accessory = No or something along these lines.
Conceptual Mass Subcategories
Wed, Jan 2, 2013 at 12:01:36 PM
Schedule subcategories
Fri, Jun 29, 2012 at 2:59:03 PM
Cannot override newly created subcategories from linked model.
Fri, May 17, 2013 at 1:44:14 PM
Dwg export: revit 2013 ignoring subcategories
Thu, Jul 25, 2013 at 8:12:43 AM
Subcategories
Fri, Jul 14, 2006 at 9:51:57 PM
Page generation time: 2.8084
