18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> join all walls with floors toguether ?? easy way?
40 Posts No Rating |
i´m making a buildg very big. join the walls with floors one by one is very boring. how you usually do it? it some join all togheter ? teh easy way with more possible?' thanks a lot..
With the TAB key select a chain of walls the attach... The TAB key is your friend...
Edited on: Tue, Apr 27, 2010 at 10:54:33 AM
i will try , thanks a lot...but work in sections too??
Yes (Sim)
Unfortunately it is not working
It does on mine .... but then I'm using ...... Ah - well maybe what you are using is not that.
Also, my walls intersect the floor above by being defined as going to the level above. In which case, I edit the floor sketch above and when finished, Revit asks me if I want to join all of those walls to my floor.
I had same problem and accidently found a solution in Revit add-ins. This one is free and works for me mehttps://apps.autodesk.com/RVT/en/Detail/Index?id=5107614544912335749&appLang=en&os=Win32_64
Edited on: Tue, Oct 17, 2017 at 2:51:59 PM
Dead horse still kicking - walls and floors strategy |
Tue, Oct 2, 2007 at 1:36:25 PM
walls overlap but dont join. |
Sat, Jul 30, 2016 at 5:13:58 PM
walls and floors (line division) |
Sat, Feb 10, 2007 at 11:01:44 AM
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
Join walls command for a group. Issue |
Sun, May 13, 2018 at 11:06:02 PM
