28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Array Parameter
40 Posts No Rating |
I am working in Revit Architecture 2010. I have created a wire mold family with an array parameter for outlets. The length of the wire mold is an instance parameter and the spacing of the outlets is a type parameter. The family seems to work as I want in the family editor. However when i load it into the project i have the follwoing problem. I load the family into the project with a certian length then i go to edit the objects instance to make the wire mold longer and the new outlets that the array parameter is supposed to add are not shown however the number of outlets increase in the tpye. I am attaching my family for whoevers use to understand my problem. thanks
Ok, what i did was: I create a new "Face Based Family" and copy/paste that "outlet" to that family, then i load into your family, delete the old outlets and paste the new family, add again the array and done.... BTW, the "Voids" now are working like they should.... Enjoy.
Edited on: Wed, Apr 28, 2010 at 4:38:41 AM
so there was something wrong with the way i was using the outlet objects? Originally i had the outlets in as a group. You have imported them in as a family. I assume it is better to array an imbebded family?
oh i forgot, thank you very much for solving the problem
Yes... and Your Welcome
Array Parameter within Family |
Thu, Aug 7, 2014 at 8:25:09 AM
Array Distance Parameter |
Thu, Apr 11, 2019 at 8:53:57 AM
Centering an Array Parameter within a Family (Wall Based) |
Fri, May 4, 2012 at 5:06:22 PM
Can't apply parameter to array number |
Fri, Dec 3, 2010 at 5:24:22 PM
visibility parameter for array group? |
Tue, Sep 11, 2007 at 3:11:24 PM
