Forums >> Revit Building >> Technical Support >> Copied Detail group glitch?
Mon, Apr 26, 2010 at 6:48:07 PM | Copied Detail group glitch?
ollienz
ollienz Avatar
Have searched hard to see if anyone else has this problem but with no joy, so here goes...
I am in the middle of extensive detailing of a main stair to a large building. I draw my main section of the stair with detail lines, fills etc (we are keeping our model very basic) and place all detail items into a group. I then make callouts of areas of the main section for details, and paste my group aligned into each callout. If i update my main section, all my details update too.
So far so good. However, if I now want to move any of the callout bubbles around, resize them etc, it causes a huge glitch within the callout view! everything jumps around and goes haywire. no families involved here, just detail lines.
Any ideas or suggestions to prevent this? or is it a bug....
thanks in advance, ollie
Tue, Apr 27, 2010 at 7:29:27 AM | Copied Detail group glitch?
Not sure what is causing the jumping.  Maybe your group origins.
Not sure why you are using groups here.  You do know that any / all annotation (2D) work can be copied to clipboard / paste same place between call-out and parent in either direction.  Groups are meant for multiple locations - not same location in different views.  If I update linework in a call-out and want that reflected in the parent, I delete the items in the parent and copy paste the updated items.
Tue, Apr 27, 2010 at 2:51:45 PM | Copied Detail group glitch?
ollienz
ollienz Avatar
Thanks, ill have a look and see if it has anything to do with the group origins. It really 'feels' glitchy though, what is happening...theres no rhyme nor reason to it.
I see your point about the two-way copy-paste feature. I just find that grouping stuff as I described does away with that extra step, having to delete items first then copy-paste into them. Wouldnt that get a bit time consuming when more than one detail is involved in the change? For instance with this stair Im drawing I had to make a finicky global change to bolt layouts on balustrade panels, which affected all 6 of my callout details. I made the changes once in my parent view, and that sorted everything else simultaneously.
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ]
Wed, Nov 23, 2016 at 3:27:29 PM
15
Revit 2011 - Glitch: once I edit a group, I cannot go out
Wed, Oct 20, 2010 at 1:34:16 PM
Error Message when i try moving curtain wall in a group
Mon, Mar 18, 2013 at 12:46:57 PM
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Detail Group Partial Visibility
Fri, Jul 15, 2016 at 10:37:44 AM
Page generation time: 0.2280
