Forums >> Revit Building >> Technical Support >> How can I pleaced the reinforcement in irregular shape slab
Mon, Apr 26, 2010 at 6:25:20 AM | How can I pleaced the reinforcement in irregular shape slab
suman143
 Respected sir/madam,
            I am facing a problem with Revit Structure, when I want to place the reinforcement in a irregular shape slab. In this case, I am using the "parallel & perpendicular rebar tool" . But the reinforce would not placed properly.
            Otherwise, I have fount that, using the "area reinforce tool bar" the problem should solved. But in this case, rebar should not visiable in 3D view and also it should not gives estimation.
 For this reason, I want a solution form you. Please help me.
Suman Paul.
Modelling Shape Code 21 or similar laid flat in Revit.
Fri, Mar 14, 2014 at 4:02:30 AM
path or area reinforcement in raft foundation
Sun, Aug 29, 2010 at 1:16:18 AM
Adding Reinforcement to a Custom Slab Thickening Family
Fri, Apr 30, 2010 at 12:27:08 AM
Revit command similar to EDGESURF in Autocad? for irregular shape 3d massing
Mon, Feb 1, 2016 at 8:34:08 AM
rebar reinforcement quantity take off
Mon, Apr 5, 2010 at 4:55:25 PM
Page generation time: 1.6063
