14 Users Online (13 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall line thickness
Mon, Sep 26, 2005 at 6:45:32 AM | Wall line thickness
nextvkin
Hi, I have some concrete walls on a slab and am trying to make them look homogenous with the slab in section. I can achieve this by joining geometry, but I can't get the line thickness of the walls to be the same as the slab. I know I can change the line thickness of ALL walls in the object styles dialog box, but I just want the concrete wall line thickness to change. Is this a possibility or do I have to use slabs to act as walls? Thanks. nextvkin
Mon, Sep 26, 2005 at 8:42:16 AM | RE: Wall line thickness
karok
I'm not sure exactly what your asking, but you can change linetype lineweight etc by typing "lw" and and changing the type of line. Does that help?
Mon, Sep 26, 2005 at 9:07:01 AM | RE: Wall line thickness
nextvkin
In the object styles dialog box the line thickness for floors is 4, and for walls it is 3. If I were to set walls to 4 to match, then all my walls will have that thickness. There is a provision at the bottom of the dialog box for modifying subcategories, so I created a subcategory under walls called Concrete walls and gave it a pen thickness of 4, leaving the main wall category as 3. However there is no connection between my concrete wall & the new subcategory.
Mon, Sep 26, 2005 at 5:47:35 PM | RE: Wall line thickness
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If there are only a few lines in particular views. As suggested by Karok. Juse use the linework tool (fountain pen) to apply a different line type to the edge in the view. (this is a view specific change) Those subcategories cannot be set to a particular wall type and are mainly for hosted wall elements such as sweeps, reveals etc. HTH.
changing line thickness in composite walls
Wed, Mar 25, 2009 at 7:11:09 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Line thickness in detail family
Wed, Jul 1, 2015 at 7:09:56 AM
Topo Cut Line thickness
Tue, Feb 14, 2012 at 10:49:24 AM
View Title Line Thickness
Thu, Jan 24, 2008 at 1:42:39 PM
Page generation time: 1.5167
