17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Roof Fascia
58 Posts No Rating |
hi,
can anyone please help me with the joining of the roof fascia at the junction as shown in the image.....
If the fascia types are the same, delete the fascia on your gable end. Then select fascia on the eaves and click "add or remove segments". Select gable end and the fascias should clean up with a mitre joint.
hi,
i have to create a cornice of this type and am unable to clean up this fascia. can you help?
17 Posts No Rating |
Hi i hade this same problem and was informed that you can produce the fascia and sofit combined profile to the straght line eaves only.
You then need to produce the Fascia and Soffit to the gable end using Generic Modals in Place.
First i the Fascia and then the Soffit.
Find attached drawing to Show this ( produced for me by Excitech suport)
Thank you!
old thread but I'm working on something similar, just wondering how the revit community would handle this now compared to back in '05.
I've created a profile for a bent flashing to act as the fascia and soffit as shown in red in the first picture. I applied the profile as a fascia to all sides of the roof and don't like the corners. The undersides extend and overlap which doesn't look too good in renderings. I'm not expecting Revit to do this for me so I'm just looking for advice on how you guys would model this. Thanks.
I would not have modeled the bottom leg. That would show in the details.
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
Roof fascia curves in plan and elevation |
Sun, Dec 13, 2009 at 1:40:44 PM
Roof Fascia On Negative Sloped Roof |
Wed, May 15, 2013 at 9:47:35 AM
roof fascia |
Fri, Jul 27, 2007 at 1:29:36 PM
Adding fascia to curved roof. |
Mon, Dec 13, 2010 at 9:21:59 AM
