Forums >> Revit Building >> Technical Support >> Keyboard shortcut problem
Fri, Apr 23, 2010 at 2:01:24 PM | Keyboard shortcut problem
Colefo
Hi Everyone, I just upgraded to 2011 yesterday and everything seems good with the exception of keyboard shortcuts. I thought the little dialog box was pretty slick but after changing and adding my usual shortcuts, I find that only a few of them work. I use "A" for align, which works just fine. I have always used "D" for the tape measure tool (from the AutoCAD days of the Distance command). When I type "D", I get dimensions. Trim for me is "T", but it activates the tag command. In the older versions I could adjust the hierarchy of these and had no problems. Does anyone have any ideas? Thanks in advance!
Cole
Thu, Apr 29, 2010 at 9:41:51 AM | Keyboard shortcut problem
Dafpfy
3.5 Stars: 11 Votes
The standard shortcut for D and T where probebly already taken by the above mentioned commands, did you look and check if they wherent set to the same shortcut key?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Apr 29, 2010 at 11:10:55 AM | Keyboard shortcut problem
Colefo
I found out that the keyboard shorcuts are supposed to be two characters long in 2011 (really lame).  In order to make the "D" work I had to delete any other shortcut that starts with "D".  It's pretty annoying but I don't think there is anything I can do about it.
Thu, Jun 17, 2010 at 10:26:54 AM | Keyboard shortcut problem
tarasmussen
Have you considered doubling the letter so you can continue to use othe "D" shortcuts? Try using "DD" for distance, "AA" for align... etc.
Looking for quick Key shortcut
Thu, Jul 2, 2009 at 10:22:19 AM
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
Exported Keyboard Shortcut file is .xml format - can't open in Excel
Fri, Jan 13, 2012 at 11:41:37 AM
Keyboard Shortcuts
Thu, Jan 20, 2005 at 5:15:30 PM
Use REVIT Shortcut Commands
Wed, Mar 31, 2021 at 7:59:28 AM
Page generation time: 3.4501
