Forums >> Revit Building >> Technical Support >> spot elevations indicating schedules symbols
Fri, Apr 23, 2010 at 12:52:33 PM | spot elevations indicating schedules symbols
arkjalomo
is there any way to put spot elevations but not to indicate the elevation, but a letter related to the elevation. I would like to do this, because im working in a sheet of levels, and certain points are so close to each other, that i would like to indicate the name of the point, and then have a schedule of all the points with its elevation...
Fri, Apr 23, 2010 at 4:46:16 PM | spot elevations indicating schedules symbols
cobblea
You might be able to make use of a Floor schedule.  You would need to assign a Mark value "A", "B", etc, to each of your different floor objects.  You could then use a Floor Tag to report the Mark value in your plans, and they would then be keyed into your schedule.  In the floor schedule, you can then report the Level of each floor, and the Height Offset from Level.  With some clever use of filters and sorting in there, I bet you could get what you are looking for.
Good luck!
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
How to resize spot elevations
Mon, May 13, 2013 at 3:35:39 PM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Page generation time: 2.0562
