Forums >> Revit Building >> Technical Support >> Visual representation of plan view ranges
Fri, Apr 23, 2010 at 10:38:20 AM | Visual representation of plan view ranges
aaronkennedy
Is it possible to show view ranges of plan views like you have for sections.  I do not mean just adjusting them in the view properties but visibly showing where the cut line is etc.
Thank you,
AAron
Fri, Apr 23, 2010 at 10:38:50 AM | Visual representation of plan view ranges
aaronkennedy
 btw I am using 2010
Fri, Apr 23, 2010 at 10:52:38 AM | Visual representation of plan view ranges
Your question is not clear.  Do you mean the depth clipping properties under view range in VP of a plan?
Fri, Apr 23, 2010 at 11:14:13 AM | Visual representation of plan view ranges
aaronkennedy
WWHUB yes I do.  When you draw a section or elevation you can visually see in the plan how far / deep the view is.  Can you do this with plan views.  Maybe in an elevation see the view depth of  your plan.  I am just having problems setting up my foundation views and wondering if there is an easier way to do it.
Thank you
AAron
Fri, Apr 23, 2010 at 11:35:50 AM | Visual representation of plan view ranges
You might try using a 3D view then using the orient to view.
Fri, Apr 23, 2010 at 11:57:19 AM | Visual representation of plan view ranges
coreed
coreed Avatar
4 Stars: 16 Votes
i know what mean. not that i know of. but that would be nice though. you go to section or elevation and turn on plan view range graphics mode for a level and drag and pull to set. nice
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
View Range visual
Thu, Dec 16, 2010 at 2:57:32 PM
Visual Style of Beams in Plan View
Thu, May 22, 2014 at 4:01:03 PM
ovverride graphics
Wed, May 21, 2008 at 6:10:26 PM
view representation for verticle opening inconsistant
Tue, Feb 24, 2009 at 7:15:03 AM
plan region view representation re: stairs
Mon, Mar 2, 2009 at 1:07:14 PM
Page generation time: 0.6868
